Activity › Forums › VEGAS Pro › Track motion not showing up in preview window
  • Track motion not showing up in preview window
    Posted by Luke Hughes on June 28, 2015 at 9:25 pm
    Hi, I have a problem in a newer version of Sony Vegas I have recently started using.
    When I open up track motion to move an object around, it wont show up in the preview window.
    For example, if I place some text in a video track above a video I have recorded, in previous versions if I open up track motion and move the text around, in the preview window it will show where I’m moving it to. However in this version I’m using now it wont, so it makes it pretty much impossible for me to use as I can’t see where I’m putting anything.
    Also, in the track motion window, if I click on a time on the timelime, it wont show that point. EG: If I click at 00:05, it will show the very first frame rather than the frame five seconds in.
    Does anyone know of a way for me to fix this? Thanks!
    David Eon replied 7 years, 10 months ago 5 Members · 4 Replies
  • Bob Peterson
    June 29, 2015 at 2:33 am
    What version of SVP are you using? Describing it as a “newer version” does not tell us very much.
    I do see a probable explanation for the failure to position itself to your current cursor. In the lower left corner of the track motion window, there is an icon with what looks like an “I” and a little lock. Click on that icon so that it is selected. That will keep the track motion cursor locked to the time line cursor.
  • John Rofrano
    June 29, 2015 at 11:48 am
    Very ancient version of Vegas use to show the path in Track Motion. Is that want you are referring to? Newer versions (since 3D Track Motion was introduced) don’t do this anymore.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Esteban Vargas
    December 16, 2015 at 9:59 am
    I have the same problem. I’m using vegas pro 13. i’ve seen tutorials and when the person is in the track motion window and they move the timeline slider to add a new positions, then move, rotate, scale the object, it all shows in real time in the preview screen. but when i try it it doesn’t happen, i can create new positions and manipulate the object, but to see what i’ve done i have to close the track motion windows and hit play in the preview screen. this is incredibly inpractical and it’s making things exponentially longer since i have to animate some 10 objects all in different tracks. any thoughts?
  • David Eon
    November 10, 2018 at 5:40 pm
    The problem is that your keyframe is “between frames”. Move the keyframe 1 frame left or right and try again. I had the same problem and just moved the keyframes a bit to fix it. Maybe someone on here has some insight into the Quanticize to frames option? I know it is a feature, but not sure what it does or if it is the culprit. Let me know if that helps!
    -DavidEon
