Activity › Forums › Avid Media Composer › track buttons
  • track buttons
    Posted by Jack Entonces on June 10, 2007 at 5:35 pm
    I know this is dumb, but I can’t remember how to remove track buttons from the timeline (not the clip on the tracks).
    I work on the Adrenalin, and I always have 4 audio tracks available to use on the timeline, but I only want to have two buttons A1, A2. How do I remove buttons A3 and A4?
    thank you
    Terence Curren replied 19 years, 3 months ago 4 Members · 4 Replies
  • Satesh Ramjattan
    June 10, 2007 at 5:39 pm
    Highlight the tracks you don’t want and hit delete.
  • Jack Entonces
    June 10, 2007 at 6:54 pm
    The was the first thing I did. That does not
    remove the track BUTTONS. I want to remove the track buttons,
    not the clips on the track.
  • Michael Phillips
    June 10, 2007 at 8:38 pm
    Turn off tracks you don’t want removed, then hit the delete key. It will ask if you want to delete the track or not. Click OK.
    Michael
    anything 24fps
  • Terence Curren
    June 12, 2007 at 4:18 am
    If you have a clip loaded on the source side it will keeps the tracks active on the right. Clear the source side before you delete your tracks and you will get what you want.
    Terence Curren
    http://www.alphadogs.tv
    http://www.digitalservicestation.com
    Burbank,Ca
