Activity Forums Adobe After Effects tracing a circle?
  • tracing a circle?
    Posted by Ryan Pinkham on April 13, 2009 at 8:43 pm
    Hi all,
    I am producing an architectural animation and need a bit of help with a seemingly simple procedure. I would like to animate a circle being drawn. I have looked at the write-on tool,etc but is there an easier way to do this?
    For reference, here is an animation showing the desired effect (at about 48 seconds in) https://www.vimeo.com/1028218
    Thanks everyone.
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Gabriel Ferreira de abreu replied 12 years, 8 months ago 3 Members · 8 Replies
  • 8 Replies
  • Scott Novasic
    April 13, 2009 at 9:30 pm
    3d stroke or just the stroke plug in and a simple circular mask is as easy as it gets.
    good luck
    SuperNova
    Animation & Visual Effects
    Scott Novasic
    Los Angeles Ca
    web:https://web.mac.com/finaleffects
  • Ryan Pinkham
    April 13, 2009 at 10:20 pm
    Thank you for the quick reply.
    I have not been working in After Effects too long so everything is very new. Could you explain a bit more for me?
  • Scott Novasic
    April 13, 2009 at 11:31 pm
    open a new comp, create a solid of any color. Use the ellipse tool to draw a circle. Then under plug ins go to generate – stroke. Make paint style on transparent and animate the start and the end of the stroke to taste. There are many ways to do this even easier than this, but its what came to mind quickly
    SuperNova
    Scott Novasic
    Los Angeles Ca
  • Ryan Pinkham
    April 14, 2009 at 1:11 am
    So I followed the instructions you gave and still nothing
    1. Create new Composition
    2. Create solid (right click in timeline and New>Solid
    3. Create Ellipse (stroke only)
    4. Effect > generate > stroke
    5. Paint style = on transparent
    6. Click stopwatch next to ‘Start’, change percentage
    7. Slide timeline slider over
    8. Click Stopwatch next to ‘End”, change percentage
    9. Play back…..nothing, except the gray Solid?
    Any ideas?
    I appreciate the help very much, thank you.
  • Scott Novasic
    April 14, 2009 at 2:27 am
    you do NOT ‘create ellipse’ you use the ellipse TOOL to manually draw an ellipse which will essentially crop your solid area in the shape of an ellipse. When you choose stroke and select paint style ‘on transparent’ the solid center of the layer will disappear leaving ONLY a white stroke around your ellipse. Animate it any way you want.
    SuperNova
    Scott Novasic
    Los Angeles Ca
  • Ryan Pinkham
    April 14, 2009 at 3:07 am
    ok, figured out the problem. I was using the ellipse tool and it was not on the layer for the solid I created. It is working great now!!!
    One more question for now, how would I go about creating the outline of a more complex shape. For example, if I had 2 or 3 or more circles that were merged together to make one object (think like the number 8, without anything in the middle). Or any shape, for that matter…
    Thank you!
  • Ryan Pinkham
    April 14, 2009 at 3:24 am
    Actually, I figured it out. Using the same process as described above, I just copy and pasted the more complex shape from Illustrator. Thanks for the help, this is really a great resource!
  • Gabriel Ferreira de abreu
    December 15, 2013 at 7:33 pm
    Where do i find this paint style to put on transparent?
