Activity › Forums › Adobe After Effects › Traced AI file, AE creates shapes with no fill?
Posted by Justin Crowell on May 16, 2013 at 5:51 pmHi all,
I’ve traced a TIF with transparency in AI. I then bring it into AE, use the “Create Shapes from Vector Layer” option. I get what is pictured below: what looks like an outline path (the shape layer is also called “**** Outlines.”Any idea why it is creating an outline, and not a shape? And so, how would I go about getting those outlines filled in?
-JustinVideo editor, animator, composer, producer
JustinCrowell.comJustin Crowell replied 13 years, 4 months ago 3 Members · 11 Replies -
Justin Crowell
May 16, 2013 at 6:19 pmI tried everything I could possibly think of, from copy the paths and masks and pasting them in other layers, to adding a fill effect. Finally, I tried exporting from AI as an EPS file. And it WORKED. IS this just a bug?!
JustinCrowell.com -
Ridley Walker
May 16, 2013 at 6:32 pm -
Justin Crowell
May 16, 2013 at 6:36 pmIt had the same fill that it had whilst still in Illustrator. The key difference here, though, is that this was an item that was Image Traced. It works fine when I generate my own vectors in Illustrator with drawing tools.
JustinCrowell.com -
Todd Kopriva
May 16, 2013 at 9:21 pmBe sure to submit a bug report:
https://www.adobe.com/go/wish———————————————————————————————————
After Effects team blog
Ridley Walker
May 16, 2013 at 10:12 pmI just tried the same thing. Traced a Photoshop image in Illustrator, clicked the Expand button to generate paths from the trace. Viewed the wireframe and cleaned up the stray bits in Illustrator. Imported to After Effects, converted to shape layer with no problem.
Justin Crowell
May 17, 2013 at 3:09 pmOk, whoa. I always struggle with illustrator. It’s the “expand” part that I missed. I’m not sure what that command actually does, but it made it work. Any chance you could enlighten me?
Thank you Ridley!
JustinCrowell.com -
Justin Crowell
May 17, 2013 at 3:42 pmI read the manual, but have to admit that I still find the concept of “expand” entirely baffling…
JustinCrowell.com -
Ridley Walker
May 17, 2013 at 4:50 pmPrior to expanding the path the traced object is seen as a single item. Expand generates paths from it.
Justin Crowell
May 17, 2013 at 7:52 pmHmm, so After Effects needs to see multiple paths as opposed to a single item?
JustinCrowell.com -
Ridley Walker
May 17, 2013 at 8:37 pmThis is an Illustrator issue. It has some other method of storing path data for traced objects, symbols etc.
