Activity › Forums › Maxon Cinema 4D › TP follow spline preset… problem with multiple spline
  • TP follow spline preset… problem with multiple spline
    Posted by Emelie Simard on May 12, 2010 at 5:02 pm
    I’ve got a problem using Tp follow spline with more than a spline.
    For each spline I’ve put an individual standart emitter, an individual fallow spline and a specific group of particles.
    The problem is, when the spline are closed from each oders, the particles mix together and choose one of the spline…
    Basicaly, I want to recreate multiple line of particle with different path in the same time…
    I try an other preset ; Move on spline… then i can have more than on standart emitter…
    thank you very much
    sorry for my english ;P
    Émélie
    Emelie Simard replied 16 years, 4 months ago 2 Members · 2 Replies
  • Brian Jones
    May 13, 2010 at 1:01 am
    you need to use Particle groups. Put each separate stream of particles in a Particle Group then use the groups in the Follow Splines. Each group will only follow it’s own spline then.
  • Emelie Simard
    May 13, 2010 at 12:49 pm
    thank you very much for the respond
    infortunatly, it’s what i did at the start…it’s work well when the spline are far from each other… but since they’re close, all the particules mix-it up on one of the spline, they choose the spline the more closed….
    do you have another solution?
    thanks!
    émélie
