Touch Screen Button Active Area
Hello –
I am trying to create an interactive presentation for a touch screen DVD system using Encore menus only (no actual video clips or timelines in this one). The first level of menus contains 5 linked menus selectable from the button on the left hand side. The first 4 of these just contain images and text like the one in the upper left of this screen cap.
The fifth button on the left menu links to the lower left screen, which in turn has buttons to link to the upper right screen (x6), which in turn has buttons to link to the lower right screen (x60).
I using Encore CS3, a Pioneer DVD-V8000, and a Cybertouch O3200 (AKA NEC MultiSync LCD3215). The button command area on the touch screen does not match the area I have defined for the button in Encore. The farther the button is from the upper right corner the worse the correlation becomes. I’ve tried changing the resolution of the project, eliminating eveything from the button I can like layer effects and text blocks, and even creating buttons underneath the image that would match where I think the touch screen would activate correctly.
The instructions from the vendor that sold us the equipment are only 1.5 pages. The only relevent thing there states “The sub menu overlay defines the active area of the button on the display. For a touch screen activated button this is defining the touch screen coordinates which will activate the visual button. The most critical part of the menu development is creating the sub menu overlay such that the active area of the button registers exactly beneath the visual button. The touch screen reports coordinates as 740×480 with 0,0 in the upper left corner.”I have tried authoring the whole project at 740×480 with no effect, and that doesn’t make sense anyway since the resolution specs are listed as 1366×768 for this monitor, which isn’t an option in Encore. I can’t find a single reference anywhere online to “sub menu overlay” in Encore except to pull up this same instruction sheet.
HELP!! What am I missing here?
Kim
