Totally Lost
Hi everyone, I have been digging around for about a day now and I cannot get a specific answer or a scenario to work for us. I know posting here will begin the end of my search as you all help more than the actual companies themselves (I have asked AJA for help but it’s only been a day so I can’t complain yet.)
I work at a digital video school where the IT dept. has changed the login for the computers for the students, each student gets their own login account on any machine. Now we are having difficulty in keeping our 1 Kona LHi happy in the edit bay. It will not playback to the external grading monitor through FCP or color. Granted the monitor is an older SD but it looks superb through After Effects without fiddling with anything. I have tried multiple set-ups in FCP to get real-time playback. No luck. All I get is a single frame. I have read the other posts and tried the solutions with no luck. I followed the (or what I think is) the proper setup:
Video is both Pro Res 422 LT and DVCPro1080 running at 23.98, so my easy setup is for ProRes 422 1080.
Sequence settings are HDTV 1920×1080 square pixels with ProRes 422 as the codec.
Video playback is AJA ProRes 422 1920×1080
In the AJA control panel we have to set our primary to 525i out of the SDI to get anything since it’s an older SD CRT monitor, (school too cheap for real HD coloring monitor as IT deems it unnecessary for color grading, proves they know nothing, go figure it’s IT)For some reason it was working fine with 1280 material @ 29.97 a month ago but now that other users will be using the edit bay with mixed media and frame rates (remember they are students) they will always have to change their settings per project. What are the real settings to be for 1920 ProRes 422?
Does it really depend on the codec if the card is playing it out? Why does it not see the monitor for Color? It works fine with AE and gives us only the frame the current time indicator is resting on and absolutely nothing from Color. And yes, they will be working off their externals through FW800.
We are running 2- 30 incher cinema displays each with their own card and the Kona LHi, with nothing to the card only going out to the monitor. Any help from this knowledge base would lift my spirits and be able to relax the impatient beast that is students.Running: Mac Pro Dual Six core
Dual 30in monitors
32 gig memory
2 internal HD’s
Kona LHi
nothing else.Thanks a million! Any other info, just ask away!
-KeithReality? What did you make it?
