Activity › Forums › Compression Techniques › Total newbie :(
  • Total newbie :(
    Posted by Thomas Monk on April 2, 2013 at 4:16 pm
    I must be thick, because I just can’t get my head around ffmpeg. Here’s what I’m trying to do:
    I have a folder “C:frames” that contains 58656 jpg images (1920×1080). These images are named “frame-000000.jpg” to “frame-58655.jpg”. These images are not interlaced.
    I would like to be able to convert a consecutive number of these frames into both HD mpeg4 1920×1080 format and PAL mpeg2 DVD 720×576 format at high quality.
    Although the images are in 16×9 format, the image is actually 4×3 with black bars to each side. When converting to 720×576 I would like to crop the side bars.
    I’ve managed to create a movie with a single frame, but that’s about it. Please help.
    Thomas Monk replied 13 years, 5 months ago 4 Members · 15 Replies
  • 15 Replies
  • Lou Logan
    April 2, 2013 at 5:24 pm
    [Thomas Monk] “When converting to 720×576 I would like to crop the side bars.”
    How much from each side would you like to crop?
  • Thomas Monk
    April 3, 2013 at 8:17 am
    210 pixels from each side.
  • Thomas Monk
    April 3, 2013 at 1:43 pm
    Sorry, I left a zero out my last frame number, should be “frame-000000.jpg” to “frame-058655.jpg”.
  • Jim Sustacek
    April 3, 2013 at 1:51 pm
    Here’s a basic command to concatenate your images into a movie, based on this blog post about time-lapse movies:
    ffmpeg -f image2 -r 25 -i frame-%05d.jpg -c:v libx264 output.mp4
    “-r 25” is your frame rate, and “-c:v libx264” would be your codec/quality settings. Feel free to adjust those or swap in other codec/quality settings you may find around the web.
    You should also be able to use the crop filter (format width:height:x:y, see filtering guide here) and the “pal-dvd” target for your PAL DVD encode like this (although I haven’t tried it yet):
    ffmpeg -f image2 -r 25 -i frame-%05d.jpg filter="-vf crop=1440:1080:240:0" -target pal-dvd output.mpg
  • Jim Sustacek
    April 3, 2013 at 1:53 pm
    Amending my other post, which assumed 240 pixel cropping, here’s a 210 pixel crop:
    ffmpeg -f image2 -r 25 -i frame-%05d.jpg <b>filter="-vf crop=1500:1080:210:0"</b> -target pal-dvd output.mpg
  • Thomas Monk
    April 3, 2013 at 3:53 pm
    Thanks for your help Jim. Do I need to specify the full path; i.e. C:\frames\frame-%05d.jpg ? And in light of my slight filename amendment; i.e. frame-000000.jpg to frame-058655.jpg do I need to put frame-%06d.jpg ?
  • Thomas Monk
    April 3, 2013 at 7:35 pm
    Sorry Jim, but this doesn’t seem to work at all. I think something has gone awry with spurious formatting such as “ “.
  • Reuben Martin
    April 4, 2013 at 1:22 am
    Don’t copy the html “bold” tags that got placed in there for some reason.
  • Thomas Monk
    April 4, 2013 at 2:43 pm
    I’m running the following single line in a batch file (run.bat):
    ffmpeg -f image2 -start_number 7723 -r 25 -i /tmp/img%05d.jpg filter=”-vf crop=1500:1080:210:0″ -target pal-dvd output.mpg
    But ffmpeg keeps reporting that it cannot find the file:
    /tmp/imgC:Program Filesffmpegbinrun.bat05d.jpg
    For some reason % is being replaced by the path and name of my batch file.
    This is driving me bonkers!
  • Reuben Martin
    April 4, 2013 at 10:36 pm
    Using ffmpeg within a bat script is quite messy. It parses text differently than a posix compliant shell does.
    You will have to escape the “%” character in order to use it within a bat script. It’s been a long time since I’ve used bat files, but if I remember correctly you can escape that character by doubling it up. (“%%” in place of “%”)
    You might save yourself a lot of trouble by installing a windows port of bash, and using that to write shell scripts rather than bat scripts.
