Activity › Forums › Compression Techniques › Total newbie :(
  • Lou Logan
    April 5, 2013 at 6:29 pm
    [Jim Sustacek] “filter="-vf crop=1500:1080:210:0"
    filter= and its associated quotation marks should be removed.
  • Thomas Monk
    April 6, 2013 at 10:40 am
    Okay, thanks guys. That double %% did the trick and I also had to put path names in 8.3 format; e.g. “Program Files” became “Progra~1”.
    I have some issues with output format/quality and cropping at the moment, but I’m sure I’ll get that sorted now I’m actually generating a movie.
    Here’s the basic batch file entry I’m using at present:
    ffmpeg -f image2 -r 24 -i C:\Progra~1\ffmpeg\frames\reel_1\frame-0%%05d.jpg -target pal-dvd movie.mpg
    The -start_number option works, although I can’t find it mentioned anywhere. I was trying to find if there’s an equivalent -end_number option. I’ll have an experiment.
  • Reuben Martin
    April 6, 2013 at 4:14 pm
    There is a “-t” option to specify duration from the start point, or there is a “-to” option to specify the stop point.
    The official documentation can be found here: https://ffmpeg.org/ffmpeg.html
  • Lou Logan
    April 7, 2013 at 7:10 pm
    Additional documentation is here: https://ffmpeg.org/documentation.html
  • Thomas Monk
    April 8, 2013 at 8:03 am
    Thanks Lou 🙂
Page 2 of 2
