Activity › Forums › Apple Final Cut Pro Legacy › Total duration of clips in a bin
Posted by Michael Pye on November 24, 2009 at 2:59 pmHi guys,
Does anybody know of a way of determining the total duration of a given set of clips in a particular bin?
MichaelAndy Mees replied 16 years, 9 months ago 5 Members · 8 Replies -
John Fishback
November 24, 2009 at 9:29 pmThis is a guess. Select the bin, then Export Batch List. Import that into Excel then sum the duration column. You may have to find a routine that adds time properly if that’s not already an option in Excel.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Michael Pye
November 25, 2009 at 10:02 amThank you, John – superb thinking. I found of course I had to delete the frame numbers from the end of each value and also and ‘format > cells’ as ‘time’ but that only took a few moments. Thanks!
Macbook Pro 15″, 2.53GHz Intel Core 2 Duo, 4GB 1067 MHz DDR3, Nvidia GeForce 9600M GT; OS X 10.5.8, Final Cut Pro 6.0.6
Andy Mees
November 25, 2009 at 1:21 pmSimply select the clips or bin you want to measure and choose File > Media Manager … roll you cursor over the dark green “Original” bar and it will turn bright green and show you how much disc space the selected media uses plus the total duration.
Hope it helps
Andy -
Michael Pye
November 25, 2009 at 4:49 pmBrilliant, that is a great deal simpler! Many thanks.
John Fishback
November 25, 2009 at 7:43 pmAndy, you’re a font of wisdom. Thanks.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Neil Sadwelkar
December 2, 2009 at 1:35 pmYou can even select all clips and drag them to an empty sequence. The length of the seq is the total length of all clips. Be sure to remove any in and out marks in each clips. You can even do that in the browser by right-click on the in TC (in the In column) and selecting Clear in. So also for remove out.
Neil Sadwelkar
neilsadwelkar.blogspot.com
twitter: fcpguru
FCP Editor, Edit systems consultant
Mumbai India -
Andy Mees
December 2, 2009 at 1:52 pmHahaaaa … a fellow cat skinner eh? … right then, well you can also Select All (or just the bin) and then choose Batch Capture and that’ll show you the Total Disk Space and Total Media Time too 😉
