Activity › Forums › Apple Final Cut Pro Legacy › Toshiba announces High Def DVDs
  • Jerry Hofmann
    June 9, 2005 at 3:10 am
    What? DV is “higher quality” than say h.264 HD? what are you saying here?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Rob Gee
    June 10, 2005 at 9:04 pm
    Of course, I meant compress standard DV at higher quality than the standard MPEG-2 60MM codec. So that a 20 minute piece that burns about 1.5 GB might burn upwards of 7 or 7GB. Wouldn’t this be higher quality, or am I mixing up my numbers?
