Activity › Forums › Adobe After Effects › top line of video field flckering
  • top line of video field flckering
    Posted by Marcosh on November 11, 2008 at 6:32 pm
    Hi there,
    I’m working with some uncompressed 10 bit footage on AE CS3 and when I play it on the composition and/or render out I see the higher or the top line of every other frame/field flickering.
    I checked the interpret footage settings and everything seems to be ok (separate fields / lower field first, Pixel aspect ratio DV/D-1)…
    I’d appreciate if any of you guys could help me out!
    Marcos H.
    Quad G5
    2GB RAM
    OS 10.4.7
    FCP 5.0.4
    AE 6.5
    Marcosh replied 17 years, 10 months ago 2 Members · 4 Replies
  • Marcosh
    November 11, 2008 at 6:45 pm
    Thanks, Dave.
    Just one question: when I create a new comp, by simply dragging the aforementioned clip onto the “comp icon”, that line doesn’t show.
    The settings between both comps seem to be the same though.
    Should I be checking something else.
    Quad G5
    2GB RAM
    OS 10.4.7
    FCP 5.0.4
    AE 6.5
  • Marcosh
    November 11, 2008 at 6:53 pm
    I actually just found out what’s happening. I had time-stretched it 50%…
    Still, isn’t there anyway I could fix it? Although it’s outside the TV screen safe area, I’m afraid that as that’s going to be on a DVD, if someone plays it on the computer they’ll be able to see the line.
    Thanks again,
    Marcos H.
    Quad G5
    2GB RAM
    OS 10.4.7
    FCP 5.0.4
    AE 6.5
  • Joey Burnham
    November 11, 2008 at 7:23 pm
    Sound to me like you’re just seeing the VITC. This is quite common actually. I usually just crop it out with a mask.
    Joey
  • Marcosh
    November 11, 2008 at 7:52 pm
    Thanks, guys. I’ll try scaling it a bit.
    Quad G5
    2GB RAM
    OS 10.4.7
    FCP 5.0.4
    AE 6.5
