Activity Forums Maxon Cinema 4D Tooth Paste coming out of tube
  • Tooth Paste coming out of tube
    Posted by Pierre Tessier on April 4, 2017 at 5:20 pm
    Trying to simulate tooth paste coming out of a tube. If you look at the file, I’m using a cloner, emitter and tracer. Looks OK so far but can’t seem to be able to fine tune the animation. I want the paste to come out slowly and in a straighter manner. Also, I want the tooth paste to stop moving once it touches the floor.
    11210_toothpaste.c4d.zip
    Pierre Tessier replied 9 years, 5 months ago 2 Members · 2 Replies
  • Brian Jones
    April 5, 2017 at 12:06 am
    using a dynamics tag set to Soft Body is why the cloned spheres all can move as a unit as the later spheres are added. Straight rigid body can have a better results for movement but the end result all lays flat rather than having vertical folds as well.
    11214_toothpastetrial.c4d.zip
  • Pierre Tessier
    April 5, 2017 at 2:03 am
    Thanks Brian. Did not think of using Rigid Body tag.
