Activity Forums Apple Final Cut Pro Toggle clip appearances?
  • Keith Strand
    June 3, 2013 at 3:37 am
    Okay here we go super late in the game, and I never post so if this is old news pardon.
    To toggle appearances I found the following work around did the trick.
    1. set the max clip height manually in the toggle view using the slider below the time clip icons
    Choose a height that makes sense for your monitor size …
    2. Use the following keyboard shortcuts
    control + option the number pad 4 , 5 , or 6 respectively
    this let’s you toggle from smallest to largest clip height the largest being what you manually set in the little light switch pop up box lower right hand side below the time line.
    CHeers
    Keith
Page 2 of 2
