Activity › Forums › Panasonic Cameras › toast 9 workflow
toast 9 workflow
Posted by Bob Torrez on January 30, 2009 at 10:31 pmAny step by step inst. for 150 footage .MTS file into toast 9
can not find export.
please help
g5 dual fcp 5.4
Thanks btBob Torrez replied 17 years, 7 months ago 2 Members · 3 Replies -
Michael Fountain
February 3, 2009 at 4:24 amHey Bob,
Mind sharing your toast 9 tips? I too am a toast 9 user and would appreciate any info..
Thanks Much
Bob Torrez
February 4, 2009 at 8:57 pmnot sure if this helps..drag your mts files into toast.
Hit the record button, there you will have choices.
I went with AIC, check your size settings etc. and export.
Import your exported files int fcp. If your sequence settings are correct, you should be able to work away…no red line or rendering needed.also make sure you are in convert in toast.
