Activity › Forums › Apple Final Cut Pro Legacy › To export video files with alpha channel in FCP7
  • To export video files with alpha channel in FCP7
    Posted by Pablo s. Herrera on July 19, 2011 at 5:20 pm
    Hi everyone, good to say hello.
    I experienced editor, user and fervent fan of the FCP… until the sadly to the new release of FCPX but that’s a topic for another post, not this.
    At this time I come to forum seeking help for a problem I have exporting files with Alpha channel from FCP7. I tried logically uncompressed QT, QT with Animation codec, and QT with PNG codec, up there in QT … but none of them work, some because they are too heavy to play full HD video on a server of material for live events based on WinXP/Win7 and the other because it loses the alpha to play it on Windows … !!! (yes, I know, but I can’t change the server, is a Pandoras Box Server from Coolux!!)
    So comes the question: anyone know of any other format for HD video, hopefully designed for Windows, to keep the alpha and can be exported from the FCP7? … no matter that must to buy and install a codec on my Mac.
    I appreciate the help
    Greetings from Bogotá,
    Pablo
    Ken Seehart replied 13 years, 8 months ago 4 Members · 4 Replies
  • David Rowan
    July 20, 2011 at 5:37 pm
    This is the formula I use to export a clip from FCP7 with an alpha.
    Change the timeline to the “Animation millions of colors +” codec. It can be any size or aspect ratio.
    Do not render the timeline.
    Export Quicktime as “Self-contained” but do not render all frames.
    The final product will be a video clip in the animation codec where all the transparencies have been preserved by alpha channels.
    Keep in mind that the animation codec is very large and demanding. Only very powerful systems can play it smoothly, if at all. I use this when creating a video element that I am going to edit in over other video repeatedly (Such as an animated corner “bub”)
    DWR
  • Pablo s. Herrera
    August 12, 2011 at 9:30 pm
    Hello Dave,
    Thanks for your help, to answer your question, effectively the problem is the high bit rate, the server is unable to play it smoothly, in fact it hangs because the material is quite large …
    I was hoping there was any other codec or format that would allow me to do, at least try it, but I have to keep doing chroma key, with the nasty problems that presents the keys at live events…
    Thanks again for your time.
    Pablo S. Herrera
    Senior Editor
    Espacio Virtual – Bogotá, Colombia
  • Peter Hall
    December 3, 2011 at 1:04 pm
    Thank you David, yours was the only post that mentioned “not to render” in order to preserve alpha channel, the only post here that worked for me to enable me to use some Motion 3D text barrells around from front to behind some small images. Looks like I will have to finish that project in Motion. Thanks again for valuable tips.
    Peter Hall
  • Ken Seehart
    January 16, 2013 at 10:13 pm
    Seems like everyone, including myself, dreams of good compression in a codec that supports alpha channel. I’m not a video expert, but I can’t think of any technical reason why alpha channel support is so poor in the industry. Certainly I would expect the alpha channel to have favorable statistical properties for compression (e.g. correlations with nearby pixels and with color channels).
    Perhaps certain kinds of lossy compression might cause artifacts if the alpha channel were treated exactly like color, but with hundreds of brilliant engineers, someone should be able to figure it out. I would try myself, but I can’t be an expert in every field 🙂
    I’ve always been frustrated by poor alpha support in nearly all graphics libraries as well, where the alpha is handled rather badly (and sometimes not at all).
