Activity › Forums › Adobe After Effects › To bring only clips used in FCP into AE workflow
  • To bring only clips used in FCP into AE workflow
    Posted by Jeff Rouric on August 29, 2013 at 9:53 pm
    Hi, I feel like I’m missing a crucial step here.
    I’m trying to move only the pieces of footage that I used in a sequence in FCP into AE for final effects.
    Right now I’m doing that by using the Copy in Media Manager, with the clips in the timeline that need effects highlighted. This way it makes new media clips for them with handles, and then I can take those clips and bring em into AE, export as the same codec, and drop them back in at the same time in the original project file.
    Is there a better way???
    Also I’ve tried Popcorn Island’s FCP2AE script, but it won’t work with this project, says something about parameter 6 being NaN… probably because the client has me working with h.264/proxies. So other than FCP2AE, any better way?
    EDIT: Copy didn’t do what I thought it was going to do, still ended up with full clips. Guess I’m gonna cut them down to the needed sections in MPEGStreamClip instead…
    Jeff Rouric replied 13 years, 1 month ago 2 Members · 2 Replies
  • Todd Kopriva
    August 30, 2013 at 4:07 am
    Why are you using this script from Popcorn Island? There is a feature built into After Effects (CS6 and later) for importing FCP XML files.
    See this video for how to use this built-in feature:
    https://www.video2brain.com/en/lessons/using-pro-import-after-effects-for-projects-from-other-applications
    If you have a previous version of the application, you can still use the same feature; you just need to download it from the Automatic Duck website: https://www.automaticduck.com/products/piae/
    After Effects team blog
  • Jeff Rouric
    August 30, 2013 at 7:01 am
    Lovely. That’s been there the whole time. Whole thing gets brought in as one intact sequence, some effects work as well. Neat and laid out in order. No worries about handles. No redoing clips to bring them in…
    I’m going to go leave a note for future me and then kill myself 😛
    And Dave, yeah this client only gave me h.264 footage to work with, no raws.
