Activity › Forums › Apple Final Cut Pro Legacy › to all who can program plug ins….
  • to all who can program plug ins….
    Posted by Stefan Kroesbacher on September 23, 2007 at 4:45 pm
    Hi all,
    i wonder if someone could write a plug in that does the following:
    Source file is HDV 1080i50
    Sequence is 16/9 SD Pal progressive
    what tha plug in should do:
    take frame 1 upper field
    deinterlace (or better – make the field a full frame by blending, duplicating or merging)
    scale to 16/9SD
    make it frame 1
    take frame 1 lower field
    deinterlace
    scale to 16/9SD
    make it frame 2
    take frame 2 upper field
    deinterlace
    scale to 16/9SD
    make it frame 3
    take frame 2 lower field
    deinterlace
    scale to 16/9SD
    make it frame 4
    what for?
    that’s the best way to get slowmotion out of the fx1…
    if you do it in FCP now you get a slowmotion that seems to
    concentrate on one field only, and therefor has to calculate
    the in-betweens, although this info is available in the other field
    what i can do in AE is:
    interpret the footage as 12.5fps, put it in the SD Comp 25fps and voila:
    slowmotion at the best quality imaginable…
    this AE-way is not possible in any of the FCP Studio2 Programs…
    so, all of you who can do a little programming:
    HELP!!!!
    thanx
    stefan
    Stefan Kroesbacher replied 19 years ago 4 Members · 4 Replies
