Activity Forums Apple Final Cut Pro TKY Free FCPX Generators (x2), Effects (x2) and Transitions (x3) NEW!
  • TKY Free FCPX Generators (x2), Effects (x2) and Transitions (x3) NEW!
    Posted by Simon Ubsdell on August 7, 2011 at 4:59 pm
    Here is a bumper selection of new FCPX effects:
    Generators:
    – ROLLING CLOUD GENERATOR with controls for roll direction, color, above/below, etc.
    – COLORED SPARKLES GENERATOR – not sure this is much use to anyone but as with the cloud generator I thought I’d try and emulate one of the Sapphire plug-ins just to see what was possible in Motion 5.
    2752_tkygenerators.zip
    Effects:
    – FLICKER EFFECT with options for brighten flicker, darken flicker, or both, etc.
    – BOKEH LENS BLUR EFFECT, much better than a straight blur for simulating in-camera out-of-focus effects.
    2750_tkyeffects.zip
    Transitions:
    – RAYS DISSOLVE EFFECT, using light rays with controls for direction, etc.
    – DISPLACE DISSOLVE EFFECT, using the luminance of the incoming image to distort the outgoing and vice versa.
    – and finally, in honour of the Great British Summer, a RAINY WINDOW DISSOLVE EFFECT, which speaks for itself.
    2751_tkytransitions.zip
    As always, any suggestions much appreciated.
    Simon Ubsdell
    Director/Editor/Writer
    http://www.tokyo-uk.com
    Simon Ubsdell replied 15 years, 1 month ago 2 Members · 2 Replies
  • David Battistella
    August 9, 2011 at 10:18 am
    The bokeh filter is maybe set to high at 50 as the default. It made FCP X beachball for quite a while on my machine i7 Laptop with 8GB RAM.
    Flicker is nice.
    David
    ______________________________
    The shortest answer is doing.
    Lord Herbert
    https://vimeo.com/battistella
  • Simon Ubsdell
    August 9, 2011 at 8:17 pm
    Here’s a new version with a much lower default setting and an option for pushing through the highlights which ought to be useful for this effect.
    Note that it is always going to be quite a heavy effect to process but I think the results are worth it if you are looking for a more genuine lens blur effect than you can achieve by other means.
    2764_tkybokehlensblureffectv2.zip
    Simon Ubsdell
