Activity Forums VEGAS Pro Titling/Text Issues
  • Titling/Text Issues
    Posted by Charles294 on January 25, 2007 at 11:23 pm
    So I’m having a title that’s pretty complex and things flying in and flying off and growing and shrinking and all that… and for some reason when I make the Text or title fly off the side of the screen it just gets cut off like there’s a mask somewhere on the right side of the screen that it’s going behind. It just starts to disappear before it even gets off the screen. I’ve tried changing the maintain aspect ratio to off, cause that sometimes seems to help, but it still does it, and I tried turning on and off my layers that have masking on them to see if that might be causing the problem, but none of them seem to change what’s going on with the title… help!!??!?!
    Charles294 replied 19 years, 7 months ago 3 Members · 5 Replies
  • Gary Kleiner
    January 26, 2007 at 1:29 am
    Is the track motion for that track set to the default?
    How are you making things fly around?
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Charles294
    January 27, 2007 at 5:38 am
    using event pan/crop to make things move
  • Mike Kujbida
    January 27, 2007 at 2:30 pm
    A real stab in the dark here but is Stretch to fill frame (Event Pan/Crop – Source) set to No?
  • Charles294
    January 27, 2007 at 6:51 pm
    well it seems utterly randomized. like sometimes if I uncheck both that and maintain aspect ratio the images are perfectly fine and there’s nothing cut off at all, but then other times it doesn’t help at all. I’ve tried it both ways. It seems like the size of the document is the problem. For instance I just imported an image of an apple as a .psd file with a transparent background. And so when i move the appple around the size of the canvas of the .psd seems to act like a mask… I move it to the right and once it goes past the edge of where the transparent canvas ends the apple just starts disappearing… I’m so frustrated!
  • Charles294
    January 27, 2007 at 6:56 pm
    So it seems like it’s just an issue with canvas sizes in photoshop translating to vegas. I went back into photoshop and changed the width of the apple image’s canvas to like 3 inches wide instead of 2, not changing the apple itself at all. Then using it in vegas, if I unchecked the maintain aspect ratio it is perfectly fine and doesn’t cut anything off anywhere onscreen… hope that helps pinpoint the problem a bit better… but there’s still the issue of the text being cut off, and that’s text that’s being created in vegas itself, not imported at all.
