Activity › Forums › Apple Final Cut Pro › Titles not able to be copied from imported Project XML
  • Titles not able to be copied from imported Project XML
    Posted by Marcus Moore on January 11, 2014 at 9:08 pm
    So I’m working on a large project with many videos, and they all need to be subtitled.
    In the interest of time, I’ve farmed out some of the subtitling to other editors.
    One editor is on 10.0.9, and he is simply sending me the current version.project for each video he does. I upgrade that to 10.1 and copy the subtitle storyline out of his sequence and paste it into my master sequence. Great.
    The other editor is on 10.1. This will be much easier, I thought. Just get him to send me a project XML file to import and copy the subtitles storyline out of there. No luck.
    While I can open his XML file and see his subtitles fine, if I try to copy and paste those subtitles into my original sequence, all titles but the first one revert to the default Helvetica font and onscreen is just “Title” for each individual sub. Same thing if I try and export from the imported sequence to a flat ProRes444 file.
    I think this is a bug.
    Andreas Kiel replied 12 years, 8 months ago 2 Members · 5 Replies
  • Andreas Kiel
    January 12, 2014 at 2:17 pm
    It’s a bug!
    Don’t use “Basic Title” !!!
    -Andreas
    Spherico
    https://www.spherico.com/filmtools
    X-Files Pro, tools for working with FCPX
    https://www.spherico.com/filmtools/X-Files/index.html
    “He who fights with monsters should be careful lest he thereby
    become a monster. And if thou gaze long into an abyss, the abyss will
    also gaze into thee.” – Friedrich Nietzsche, Beyond Good and Evil
  • Marcus Moore
    January 12, 2014 at 3:17 pm
    Little late for this one video, but if I have to pass any more off to this editor, I’ll keep that in mind. Thanks.
  • Andreas Kiel
    January 12, 2014 at 4:00 pm
    What version of FCPX are you using?
    -Andreas
    Spherico
  • Marcus Moore
    January 12, 2014 at 4:14 pm
    Both myself and the other editor are on 10.1.
  • Andreas Kiel
    January 12, 2014 at 7:06 pm
    I’m not on a machine with 10.1 installed a the moment.
    So here something which could work (from just my memories of the bug).
    If your XMLs are tiles only there could be an option to fix.
    Open your XML in TextWrangler (free). There is a text line in the beginning which starts with " <effect id=... " followed by "uid=".../Titles.localized/Bumper:Opener.localized/Basic Title.localized/Basic Title.moti"/>"
    Create a simple project using another title which matches the “Basic Title” some how (just one title).
    Open that one in TextWrangler as well.
    Now copy the line with the effect entry in this file and replace the entry in the first file with that one.
    Make sure the “id=”r…” are the same as in the source file.
    I’ll be back on a normal machine tomorrow afternoon CET and will look for a better description.
    -Andreas
    Spherico
