Activity Forums Adobe Premiere Pro titler troubles
  • titler troubles
    Posted by Thethirdtear on November 3, 2005 at 10:46 pm
    Greetings.
    I created a rolling title (starting off screen and moving upwards) in PPro 1.5 and all seemed fine. The clip is about 35 sec long. In Pro it looks fine. In the compressed .m2v file it looks alright. But when I toss it into Encore to burn it, it looks fuzzy and jitters quite a bit.
    Is PPro 1.5 made to do extended title sequences? Is there a way to lessen, if not altogether rid, the jitteriness and fuzziness?
    Any help would be greatly appreciated.
    Thanks.
    Steve
    R. Hewitt replied 20 years, 10 months ago 2 Members · 3 Replies
  • R. Hewitt
    November 4, 2005 at 12:10 pm
    Same questions as above.
    What DVD settings are you using?
  • Thethirdtear
    November 7, 2005 at 8:12 pm
    I’m sure if I know what you mean by DVD settings?
    From what I know:
    In Encore 1.5:
    4.7GB disc
    PCM audio
    NTSC
    In PPRO 1.5:
    Video Summary:
    Codec: MainConcept MPEG Video
    Quality: 2.1 (low quality)
    TV Standard: NTSC
    Frame Rate [fps]: 29.97 drop frame
    Field Order: Lower
    Aspect Ratio: 4:3
    Frame Width [pixels]: 720
    Frame Height [pixels]: 480
    Bitrate Encoding: VBR, 1 Pass
    Minimum Bitrate [Mbps]: 3.8250 (low quality)
    Target Bitrate [Mbps]: 6.0000 (medium quality)
    Maximum Bitrate [Mbps]: 8.0000 (high quality)
    M Frames: 3
    N Frames: 15
    Audio Summary:
    Audio Format: PCM
    Codec: PCM Audio
    Sample Size: 16 bit
    Frequency: 48 kHz
    Multiplexer Summary:
    Multiplexing: None
    Project settings:
    NTSC (0.9)
    30 fps dropframe
    Thanks.
    Steve
  • R. Hewitt
    November 9, 2005 at 11:15 am
    I had a similar problem to this when encoding from within Premier Pro. It must be related to the export settings.
    I have a Matrox RTX.100 card that can encode in realtime. Using this I have no problems with titles. Bringing in the AVI sequence from Premier Pro and encoding also works without issue using Adobe Encore with the default project settings.
    I’ll give Premier a try tonight using it’s encoder and see if I get the same problem.
