Activity Forums Adobe After Effects Title Sequence for web
  • Title Sequence for web
    Posted by Laurence Mcdonald on September 3, 2008 at 8:37 am
    Just wondering, i have a job where someone wants a shiny particle glittery title sequence, something to get someone’s attention, typical thing. And they want it for the title on the website. What is the best way to go about it in after effects (it being web, has to be small file size) ie. what to export it out as etc. Cheers,
    Laurie
    Laurence Mcdonald replied 18 years ago 2 Members · 2 Replies
  • David Bogie
    September 3, 2008 at 3:10 pm
    Determine what video file format and codec your Web designer wants from you.
    Chances are you are going to create an Animation file (more or less standard for transparency and easy to transport between platforms) and then the Webhead will convert and scale it to a specific file type to run on her server.
    What you want to know is the size of the box you are filling and how long the clip needs to be and if it needs to loop seamlessly.
    Get those specifications first and post back.
    bogiesan
  • Laurence Mcdonald
    September 4, 2008 at 7:24 am
    It will be just your standard banner size, animation on loop but only loaded once (900×200) and she doesn’t really have a clue what she’s doing she just wants what i explained in previous post, i have control. Regarding format, animation makes sense. So is there anything else i should i know about, cheers :- ).
    Laurie
