Activity Forums Adobe Premiere Pro Title section in Source is different than in Timeline
  • Title section in Source is different than in Timeline
    Posted by Steve Brame on February 15, 2015 at 4:22 pm
    Why would a 13 frame section of a title be only 5 frames long when dropped into a Timeline?
    Asus P6X58D Premium * Core i7 950 * 24GB RAM * nVidia GeForce GTX 770 * Windows 7 Premium 64bit * System Drive – WD Caviar Black 500GB * 2nd Drive(Pagefile, Previews) – WD Velociraptor 10K drive 600GB * Media Drive – 2TB RAID0 (4 – WD Caviar Black 500GB drive) * Matrox MX02 Mini * Adobe CC * QuickTime 7.7.5
    “98% of all computer issues can be solved by simply pressing ‘F1’.”
    Steve Brame
    creative illusions Productions
    Steve Brame replied 11 years, 7 months ago 2 Members · 4 Replies
  • Tim Kolb
    February 17, 2015 at 4:43 am
    I’m intrigued by the question, but it’s kind of a Schrodinger’s Cat kind of question without some detail.
    Do you have a Title in the Source Window? From the PPro Title Tool?
    TimK,
    Director, Consultant
    Video Producer at I-CAR
  • Steve Brame
    February 17, 2015 at 11:54 am
    Hey Tim,
    I even have visual aids!
    However, I guess it was just a temporary glitch, since it seems to be performing correctly now. Strange, for a few days I had to jockey the size of a selection of a title in the Source monitor to get the correct length for it when dragged to Timeline. Finally just started dragging a much longer section down the resize it there.
    The weirdest part was, it wasn’t a frame for frame thing. I could change the Source selection by a frame, and drag it down and it would still be the same length as before. It would take shortening the Source version several frames to even shorten it 1 frame when dragged down.
    Oh well…
    Steve Brame
  • Tim Kolb
    February 17, 2015 at 12:25 pm
    You probably set up the in/out in the sequence to illustrate the length of the clip?
    (Otherwise I see a 3 point edit with an out on the source and in/out on the sequence?)
    TimK,
  • Steve Brame
    February 17, 2015 at 12:29 pm
    [Tim Kolb] “You probably set up the in/out in the sequence to illustrate the length of the clip?”
    Correct!
    Steve Brame
