Activity Forums Apple Final Cut Pro Legacy Title position request
  • Title position request
    Posted by Gabriele Gismondi on October 24, 2010 at 9:39 am
    Hi friends,
    i’ve been asked to put all titles in the project at “146 x 508 px” position..but i’m wondering how..in the sample image my client sent me it’s all down-left positioned (as usual for titles) but inserting these coordinates in the control or motion title’s tab i cannot get there..some tricks?
    Bret Williams replied 15 years, 10 months ago 4 Members · 5 Replies
  • Rafael Amador
    October 24, 2010 at 10:28 am
    Hi Gabriele,
    That info is not enough.
    The titles may be aligned “Right” “Center” or “Left”.
    The position you have will be OK for one of those options, but no for the two others.
    rafael
    http://www.nagavideo.com
  • Gabriele Gismondi
    October 24, 2010 at 11:09 am
    hi rafel,
    the title must be left positioned..still don’t get the point..in a 1920×1080 frame, the title jumps far away from the coordinates..
  • Rafael Amador
    October 24, 2010 at 12:12 pm
    [gabriele gismondi] “the title must be left positioned”
    Left positioned is not the same than “left aligned”.
    Alignment is a property (?) of the text and changing this you will change the position of the text, whatever the “center” (Motion tab) or “origin” (text generator).
    Play with the three alignment option.
    rafael
  • Chris Tompkins
    October 24, 2010 at 2:23 pm
    Just put it where it looks right and ask for feedback.
    Chris Tompkins
    Video Atlanta
  • Bret Williams
    October 24, 2010 at 7:01 pm
    Your client is asking for the title to be 146 px from the left, and 508 px from the top most likely. Clarify what they mean. Because in FCP the motion tab determines the center of the object from the center of the frame. Completely different from most photoshop type apps that default to the upper left being 0,0. FCP 0,0 is the middle.
    What you need is a guide made in photoshop. A vertical line 146 px from the left, and a horizontal line 508 from the top. Then just move your title into position visually.
