Activity › Forums › Adobe After Effects › Title effect: Opening Supernatural
  • Tudor “ted” jelescu
    September 19, 2012 at 11:09 am
    No plugin/effect needed. All you need to do is to duplicate the text layer several times, re-size at various larger dimensions and position at different locations in the frame. Then you can animate the opacity to create a flashing sequence- from zero to 50%, to 100% and zero again- at 1 or 2 frame intervals, offsetting for each channel so that they will come up and disappear one after the other. The main text can stay on the whole time or disappear at the begging of the flashing sequence and appear at the end of it.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Vishesh Arora
    September 19, 2012 at 12:42 pm
    Mr. Satírio
    Depth Of Field(camera property) is used to focus the main Text. This will automatically blur out the Text layer which are closer to the screen.
    Vishesh Arora
    VFX and Motion Graphics Artist
    Blog:
    https://digieffects.wordpress.com
    Demo Reel(3D):
    https://www.youtube.com/watch?v=lHPgIJU_BR8
  • Anthony Marzilli
    September 20, 2012 at 3:44 pm
    Instead of cutting the layer up multiple times you can also just set HOLD KEYFRAMES for opacity and position… and maybe fast blur if you want it to not be so clear. That way it is easy to change the word.
