Activity Forums Apple Final Cut Pro Legacy title editing
  • Posted by Emilio D’aleo on January 19, 2011 at 5:00 pm
    hi…
    I’m making the titles of a doc. I used photoshop to make the slides and then I edited them on Final Cut, but when I export the video there is a lot of noise in these titles. They fizzle while moving as something in the render went wrong or was set badly. I stopped the video to look at the single frame while the title is moving and the it has a sort of shadow or wake behind it and some parts are missing.
    Is there anyone who can help? Thank you..
    David Roth weiss replied 15 years, 7 months ago 3 Members · 11 Replies
  • 11 Replies
  • Zane Barker
    January 19, 2011 at 5:22 pm
    You have not given us any info that can actually help answer your question.
    For starters what are your timeline settings?
    **Hindsight is always 1080p**
  • David Roth weiss
    January 19, 2011 at 6:11 pm
    [Zane Barker] “For starters what are your timeline settings?”
    Wanna gamble on this one Zane? I’ll take DV and I’ll give you the rest of the field for a zillion bucks. Deal?
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
  • Zane Barker
    January 19, 2011 at 6:49 pm
    Yea I’m betting DV also.
  • Emilio D’aleo
    January 20, 2011 at 8:29 am
    I’m not using any monitor. I use in the Final cut internal window. The problem appears after I export the video in mov, when I watch it in quicktime. When I edit them on final cut there seems to be no problem.
  • Emilio D’aleo
    January 20, 2011 at 8:38 am
    the sequence settings are:
    Frame size: 1440×1080 HD (16:9)
    Pixel Aspect Ratio: HD (1440×1080)
    Field Dominance: Upper (odd)
    Editing Timebase: 25
    Compressor: HDV 1080i50
    Rate: 48kHz
    Depth 16-bit
    Config: Channel Grouped
  • David Roth weiss
    January 20, 2011 at 3:59 pm
    [emilio D'Aleo] “The problem appears after I export the video in mov, when I watch it in quicktime.”
    Quicktime Player does not play in realtime and in addition you’re watching interlaced material on a computer monitor, which is not designed for displaying the interlace properly.
    What is your final destination and size for the finished product? If you determine that, then we can help you to make that display correctly, but full-size interlaced video will not display properly in QT Player on a computer monitor.
    David Roth Weiss
    Los Angeles
  • Zane Barker
    January 20, 2011 at 6:56 pm
    In addition to what David said, I would recommend against editing in HDV.
    You would be better off to capture your HDV as ProRes and then edit, or at the vary least edit your HDV in a ProRes timeline.
  • Emilio D’aleo
    January 20, 2011 at 7:35 pm
    It’s going to be projected in an expo hall, from a mac, on a cinema screen I suppose, I’m only making the titles…
  • David Roth weiss
    January 20, 2011 at 7:57 pm
    [Zane Barker] “You would be better off to capture your HDV as ProRes and then edit, or at the vary least edit your HDV in a ProRes timeline.”
    I agree with Zane, however all you need to do is go to Sequence>>Settings and change the compressor to ProRes, then re-render.
    David Roth Weiss
    Los Angeles
  • Emilio D’aleo
    January 21, 2011 at 10:30 am
    Can you tell me wich one please? Apple ProRes 4444, Apple ProRes 422 (HQ), Apple Pro Res 422, Apple ProRes 422 (LT), or Apple ProRes 422 (Proxy)?
