Activity Forums Adobe Premiere Pro Title creation window too small
  • Title creation window too small
    Posted by Luís Jervell on September 27, 2016 at 2:28 pm
    When I try to create a new title the creation window is to small. What can I do to size it bigger?
    I use Premiere Pro CC vs 7.2.2 (33) on a Mac MacBook Pro Retina OS X El Capitan 10.11.6 and on the timeline there is a .mp4 video.
    Luís Jervell replied 9 years, 12 months ago 2 Members · 4 Replies
  • Tero Ahlfors
    September 27, 2016 at 3:19 pm
    Grab an edge of the window and make it larger. Like you would do for a Finder window.
  • Luís Jervell
    September 27, 2016 at 6:07 pm
    That doesn’t work, I cannot grab the corners. I’m talking about the black rectangle inside the gray area of the Title designer panel (image enclosed)
  • Tero Ahlfors
    September 27, 2016 at 6:48 pm
    What is the resolution of your title? If you’re using a standard resolution then the view should scale to fit. I tried with some weird small non standard resolution and it doesn’t do that.
  • Luís Jervell
    September 27, 2016 at 11:08 pm
    I think that is the key to the problem, I changed the resolution to 500×400 and the black rectangle became bigger, then I went to the effect controls and brought the scale to 71 and think it solved my problem.
