Activity › Forums › Apple Final Cut Pro Legacy › Title 3D text color is the opposite!!
  • Title 3D text color is the opposite!!
    Posted by Ryan Stegman on May 29, 2008 at 7:45 pm
    Anyone encounter this issue…I load up the Title 3D generator, type some text, and when I highlight the text and select green as it’s color, it shows up as the opposite color on the color wheel (purple). This happens no matter what color I select, except black and white show up as they should. I have encountered this before, but not for a while, and it has cropped up again. Anyone have a solution or a reason why this happens?
    Kevin Monahan replied 18 years, 3 months ago 2 Members · 3 Replies
  • Kevin Monahan
    May 29, 2008 at 10:47 pm
    That is because you are in active selection mode. Just click once in any field, then an outline around your text block will appear. Now when you change colors, you’ll see the colors show up because it’s now in passive mode. It’s in the Title 3D manual and explained in my book.
    Kevin Monahan
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • Ryan Stegman
    May 30, 2008 at 2:53 pm
    I wish it was that simple, but unfortuantely, it is not. I’ve been using FCP for about 8 years now, and this color issue with Title 3D has only happened a few times, but when it does, I can think of no solution. When I highlight my text and change its color, and edit it into the timeline, it shows up as the opposite color. The regular text tool is not affected, just Title 3D. No rhyme or reason to it. Anyone experience this rare but frustrating quirk??
  • Kevin Monahan
    June 2, 2008 at 6:35 pm
