Activity › Forums › Apple Final Cut Pro › Tip: FCP X Clip Replacement Techniques
  • Tip: FCP X Clip Replacement Techniques
    Posted by T. Payton on October 31, 2011 at 7:57 pm
    I was working on a project that had some sky replacement/set extensions and found a few nifty things about replacing clips in FCP X. Perhaps they will be helpful.
    https://www.youtube.com/watch?v=oBr9JHQkdCg
    T. Payton
    OneCreative, Albuquerque
    T. Payton replied 14 years, 11 months ago 2 Members · 2 Replies
  • Andy Neil
    October 31, 2011 at 10:21 pm
    Interesting workflow, although I would probably just detach the audio from the original clip and do a straight replace edit. If the clips were of unequal lengths, I would place the marker on the detached audio at the sync point. Then when I place a sync marker in the replace footage, I can use the trim tool to line them up.
    Still would be much easier if they just gave us a standard replace edit function.
    Andy
    https://www.timesavertutorials.com
  • T. Payton
    November 1, 2011 at 3:52 pm
    Thanks for the feedback. I addressed detaching audio, replacing from start or end, and another new technique that I think is far superior to the rest.
    https://www.youtube.com/watch?v=6XtczNjIG-A
    T. Payton
