Activity Forums Apple Motion Timing of words in a sentence.
  • Timing of words in a sentence.
    Posted by Andre Wognum on June 29, 2011 at 5:37 pm
    Greetings all!
    I just started to use Motion 4 a couple of weeks ago, so this will be a beginners question. 🙂
    How do you make the texts or words in a sentence to follow a speaker voice? In other words – how do I pause the “writing” of the text at commas, periods etc when I use a Text Animation like “Type On” or Text Sequence “Fade Characters Left in”?
    It seemed simple enough, but I can’t get it to work…
    Andre Wognum replied 15 years, 2 months ago 3 Members · 3 Replies
  • Andy Neil
    June 29, 2011 at 11:46 pm
    You can do this with the Sequence Text behavior. You create a parameter for opacity and assign it to 0. Then change the speed to custom and use keyframes to time the words fading in.
    Andy
    https://www.timesavertutorials.com
  • Mark Suszko
    June 30, 2011 at 7:20 pm
    Or the same trick can be applied to crop. Ot to the beginning and endpoint of a stroke type thing.
  • Andre Wognum
    June 30, 2011 at 7:23 pm
    Thank you very much Andy.
    I’ll give it a go in the weekend. 🙂
