Activity Forums Adobe After Effects Timewarp source frame only up to 5000?
  • Timewarp source frame only up to 5000?
    Posted by Erin Patrick on July 17, 2006 at 10:14 pm
    Does anyone know why I can’t get the source frame value of the timewarp effect above 5000.00?
    Nothing’s mentioned in the archives or help menu.
    Mike Clasby replied 20 years, 2 months ago 2 Members · 1 Reply
  • Mike Clasby
    July 18, 2006 at 12:27 am
    Right click on the value (blue numbers) and click Edit Value, you’ll get a Box for the parameter that tells the Minimum and Mazimum Values. If it says 500 there, that’s the Max, I’m not sure what it is for time warp (I’m AE6.5 handicapped), but if it says Maximum Value more than 5000, change the second Slider Range spot to the Max. Hope that helps.
