Activity › Forums › Apple Motion › Timer Countdown in Motion 3…???
Posted by Phil Muri on April 8, 2008 at 4:40 amHi,
Is it possible to create a digital countdown timer in Motion 3? For example, starting at 60 minutes and ticking down all the way to 0?
-Phil
Patrice Freymond replied 16 years, 11 months ago 5 Members · 4 Replies -
Burt Hazard
April 8, 2008 at 8:55 pmIt’s possible, but pretty tedious because you’d have to do it manually. Motion doesn’t have a text generator/behavior for it yet (Motion 3.5.1?).
Digital Heaven does have a counter plugin for FCP itself though ($20).
David Bogie
April 9, 2008 at 3:55 pmYou can also use the timecode generator in FCP over a slug. but you have no control over typefaces and other subtleties.
bogiesan
Arnie Schlissel
April 9, 2008 at 4:53 pmBetter than using a slug, you can make a black .tiff or .tga or .png with a black alpha channel, & drop the TC generator in that. In the FCP browser, you can make that blank still to be as long as you want, FCP’s slug can only be 2 minutes long.
Arnie
Now in post: Peristroika, a film by Slava Tsukerman
https://www.arniepix.com/blog -
Patrice Freymond
October 10, 2009 at 7:09 pmReviving this thread to say that there is another alternative:
1) Get the clock generator plugin for FCP from Matthias https://www.mattias.nu/plugins/, it is free but you can make a donation
2) Generate the countdown choosing style from your system’s loaded fonts
3) export to use in Motion 3
N.B. As I haven’t upgraded to fcs 3 I don’t know if said plugin works in fcp 7
Also, as for every generator in fcp, slug included, you can make them the length you want by changing their duration in the viewer.
Hope this helps
Patrice
