Activity › Forums › Apple Final Cut Pro Legacy › timeline spanned across two displays?
  • timeline spanned across two displays?
    Posted by Shayne Weyker on September 2, 2006 at 1:32 am
    I’m setting up an FCP 5.11 system on a mac pro and it won’t let me spread my timeline across two 17″ displays. Is there a way to set FCP to allow this?
    –Shayne
    Shayne Weyker replied 20 years, 1 month ago 2 Members · 2 Replies
  • David Battistella
    September 4, 2006 at 4:23 am
    There is no reason it should not do this.
    Just drag the timeline across them both. OR
    Set up you monitors correctly using the monitor control panel in the system pane.
    David
    Peace and Love 🙂
  • Shayne Weyker
    September 4, 2006 at 11:14 pm
    I have a two screen wide desktop and have played hi-res QT files that span between videos. Does that indicate I’ve set the sysytem display prefs as much as I need to?
    But when I tell it do do two screen editing format it uses only one for the timeline and it won’t let me span it.
    Also possibly relevant, my left monitor is DVI and my right one is VGA using a DVI to VGA adapter.
    –Shayne
