Activity › Forums › Apple Final Cut Pro Legacy › Timeline Setting
  • Timeline Setting
    Posted by Mike Petty on September 13, 2010 at 2:09 am
    Though I’m not having any problems it occurred to me I may not have my timeline set to the optimal format.
    I am importing footage from a Canon 7D (shot at 24FPS). I am importing using the Canon plug in converting to ProRes 422 LT.
    So simply stated…how should I configure the Easy Set Up?
    Jeremy Garchow replied 16 years ago 3 Members · 4 Replies
  • Rafael Amador
    September 13, 2010 at 2:50 am
    Hi Mike,
    No need for Easy setups when you can Conform the sequence to the clips setting.
    Drop a clip in any sequence and when FC asks you about conforming click YES.
    rafael
    http://www.nagavideo.com
  • Jeremy Garchow
    September 13, 2010 at 1:18 pm
    Mike, do you have a capture card with which to monitor your footage?
  • Mike Petty
    September 13, 2010 at 8:04 pm
    Not quite sure what you mean…
  • Jeremy Garchow
    September 13, 2010 at 8:06 pm
    [Mike Petty] “Not quite sure what you mean…”
    Then it’s probably a no. Then as Rafael says, you don’t need an easy setup. You would need one if you have a i/o card.
    Jeremy
