Activity › Forums › Apple Final Cut Pro Legacy › Timeline Question
  • Timeline Question
    Posted by Adam Taylor on July 29, 2009 at 1:59 pm
    Is it possible to display in the timeline, something that will instantly show which clips on a timeline have filters applied?
    Its not something i have ever needed before, but after being given a long timeline with lots of clips – it would be really useful to know which have the filters and which don’t.
    thanks
    Adam
    Adam Taylor
    Video Editor/Audio Mixer/ Compositor/Motion GFX/Barista
    Character Options Ltd
    Oldham, UK
    http://www.sculptedbliss.co.uk
    Kevin Monahan replied 17 years, 2 months ago 3 Members · 4 Replies
  • Neal Broffman
    July 29, 2009 at 2:08 pm
    In your sequence and user settings there is a tab called timeline options. In that tab you can select a box that will show on the timeline which clips have filters applied.
    Neal Broffman
    One Production Place, Atlanta, GA
    “Voices of Freedom”, Special Jury winner for Fall 2008 CINE Awards produced for the High Museum of Art in Atlanta as part of a major exhibition of vintage Civil Rights Movement photographs, “Road To Freedom”. Currently on display at The Field Musuem in Chicago followed by The Skirball Cultural Center in LA in the fall and The Bronx Museum, spring 2010.
  • Adam Taylor
    July 29, 2009 at 2:14 pm
    Thanks Neal,
    i’m using that setting but it seems to be inaccurate.
    According to the manual, i should see a green line under the clips that have filters applied. There are a few clips showing this, but there are also a whole heap with filters that are not appearing.
    these kind of inconsistencies really bug me!!
    regards
    adam
    Adam Taylor
    Oldham, UK
  • Adam Taylor
    July 29, 2009 at 2:31 pm
    answered my problem…it seems the indicator only appears if the filter is active. There are plenty of filters that have been applied to this timeline, but few are active, so only a few appear.
    hope that helps anyone else puzzling over this.
    adam
    Adam Taylor
    Oldham, UK
  • Kevin Monahan
    July 29, 2009 at 4:49 pm
    I just use the Clip Keyframes mode (Option + T) If there is a green bar, then there is a filter applied.
    Kevin Monahan
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
