Activity Forums Apple Final Cut Pro Legacy Timeline playback stalling
  • Timeline playback stalling
    Posted by Peter Wolsey on February 17, 2007 at 9:27 pm
    Editing on FCP5.1.2, on SD. Due to the huge amount of raw material I’ve had to capture I’v elected to offline/online, initially using Blackmagic PAL JPEG capture. The material actually looks great – perfect for basic editing – and the clips all play beautifully in the viewer. But once on the timeline they play OK for 30 sec or so then there’s a video freeze for around a second (although the audio keeps playing flawlessly). Then the video catches up with the audio.
    Also the playback from the timeline/canvas is slightly brighter than from the viewer. I’ve tried changing various sequence preset settings, but can’t pin the problem down. Probably something stupid I’m doing – but any ideas? Thanks.
    G5/Blackmagic/FCP 5.1.2
    Dkilgore replied 19 years, 7 months ago 3 Members · 3 Replies
  • Chris Tompkins
    February 17, 2007 at 9:52 pm
    What raid or hard drive(s) r u playing the media from?
    Sounds like a thruput issue
  • Peter Wolsey
    February 17, 2007 at 9:59 pm
    Good old G-RAID. They work flawlessly with 8 bit uncompressed SD from my Digi deck, so I would have thought they could handle 3mb/s. As I say, the video plays without a problem from the browser, so I don’t reckon it’s a question of slow drives. I suspect it’s a Sequence Preset issue…
  • Dkilgore
    February 18, 2007 at 7:01 am
    it’s a pain, but 1 solution could be to export a quicktime files same as source and reimport that clip for output. If you have to many cuts/renders and your drives are not fast enough to access your clips – this will work as a temp solution.
    -dk
    Donald Kilgore
    Image202 Entertainment
