Activity Forums Adobe Premiere Pro Timeline lost
  • Timeline lost
    Posted by Sébastien St-martin on February 27, 2017 at 8:12 pm
    Hi guys,
    Here’s the problem: when I open a project in Adobe Premiere CC 2017 (mac) everything seems fine until the project is open and can’t find the timeline/source monitor, workspaces, etc…
    When I hit the space buttom as a play buttom, I can hear the sound of the sequence like if the timeline is somewhere outside the display. I usualy use two screen but even if I disconnect one, it doesn’t work.
    Here’s what I tried :
    Window/source monitor… and all that stuff
    Window/workspaces (all the preset I had and all pannels)
    File/new sequence
    Open another project/new project
    Delete and reinstall premiere
    Reset premiere preference
    Systeme preference/display, arrangement, position, scale, etc…
    In the adobe window menu, I can only open the timecode window…
    My adobe premiere 2015 is working fine.
    Thanks a lot for your help!
    Sébastien St-martin replied 9 years, 6 months ago 2 Members · 3 Replies
  • Phillip Brock
    February 28, 2017 at 2:19 pm
    have you tried double clicking on a sequence?
  • Sébastien St-martin
    February 28, 2017 at 8:11 pm
    Sure!
    March 1, 2017 at 4:54 pm
    Here was the solution :
    Go to : /Users/NAME/Library/Application Support/Adobe
    Then change the name of the folder Common by Common1 and Premiere Pro by Premiere Pro1
    Then relaunch…
    Thanks to the Adobe Premiere Support !
