Activity Forums VEGAS Pro Timeline hotkey controls overriding Trimmer Vegas Pro 9
  • Timeline hotkey controls overriding Trimmer Vegas Pro 9
    Posted by Tim Riordan on June 1, 2011 at 6:47 pm
    This is my first post to the forum here, so I hope this is in the right place. I’m fairly new to Sony Vegas Pro 9, but have been messing with video audio editing for a couple years.
    Initially I was trying to enable pauseplay using the space bar, and I didn’t know there was a selection in options. So I was changing the hotkeys. Then, of course, I couldn’t remember exactly what I’d done 🙁 So I reset Vegas Pro 9 to original global default settings. Then I enabled space bar play pause under options. However, other hotkeys I’d changed b4 the global default reset, are still enabled. How do I reset all hotkeys to original global default settings? Right now if I activate the trimmer window when it is docked or undocked, the pause play preview option with space bar works fine. If I enable full screen preview with the trimmer, I see the trimmer preview where it is paused. But if I hit the space bar to play, the trimmer image doesn’t move and I hear the timeline playing (escaping to normal trimmer size confirms that the timeline is playing) If I start the trimmer preview when trimmer is docked, the preview plays. If I then switch to fullscreen it continues to play the trimmer preview. But if I then hit the spacebar to pause, it again activates the timeline. I have ensured that “Enable Timeline Overwrite” is depressed. Tried unclicking and clicking it again. I want to view the trimmer in fullscreen to see fine detail for edit points. i want to be able to just use simple hotkey functions, like pauseplay, and step frames forward back using arrow keys. For the actual editing I can just reduce to normal docked trimmer. Any suggestions on how I can enable some basic hotkey functions while in full screen trimmer mode would be appreciated. Or pointing me to a tutorial that covers this particular aspect of the program.
    Thanks. I’ve already picked up many, many good tips by reaidng previous forum posts.
    Tim
    “There are three kinds of people in this world: those who can count and those who can’t”
    Tim Riordan replied 15 years, 3 months ago 3 Members · 4 Replies
  • John Rofrano
    June 1, 2011 at 7:36 pm
    If you hold down Ctrl+Shift while starting Vegas it will reset it to the factory defaults.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Tim Riordan
    June 1, 2011 at 8:03 pm
    Thanks John,
    I realize my post was longwinded and maybe not clear.
    Using Ctrl+Shift was what I did previously to restore defaults. However, after restoring defaults, for some reason it appears the hotkey commands that I had changed were not restored. For example, to toggle full screen preview from timeline was, I believe Shift+Alt+4 by default. I had changed that to Ctrl+Z. After restoring defaults, all my properties, workspace, etc were restored, but my toggle to full screen remained at Ctrl+Z, not the original Shift+Alt+4. Perhaps I’m overlooking something, but I’m baffled. The only reason it’s problematic is that I now realize Ctrl+Z is already assigned to “Undo”. I’m just trying to work around it by re-assigning any hotkey conflicts I notice. Odd though that I would be allowed to assign a key already in use.
  • Aleksey Tarasov
    June 2, 2011 at 3:46 am
    To reset all customized hotkeys you must remove keyboard.ini file
    (open Windows Explorer, enter %APPDATA%\Sony\Vegas Pro\9.0\ and press Enter)
  • Tim Riordan
    June 2, 2011 at 8:32 pm
    Thx Aleksey
    I will try this
