Activity Forums Apple Final Cut Pro Legacy Timeline hang ups on SD DV PAL project
  • Timeline hang ups on SD DV PAL project
    Posted by Andrew Parker on September 11, 2009 at 11:44 am
    Dear Forum,
    My project is an 8 minute film in SD DV PAL. I am using a Macbook Pro with a G-Tech Raid drive.
    I am starting to get increasing RT playback hang ups- i.e. it stops playing the timeline and I have to restart the playback.
    Is there a strategy for decreasing this occurrence? I didn’t have it at all at the start of the editing process- it is getting progressively worse.
    Thanks in advance,
    Andrew Parker
    Rafael Amador replied 17 years ago 2 Members · 3 Replies
  • Rafael Amador
    September 11, 2009 at 12:32 pm
    Hi Andrew,
    in a case like that I would start by running DiskWarrior (or TechTools,..) and rebuilding the directories of all the HDs, starting by the system.
    I would check as well the raid performance with the AJA tool.
    cheers,
    rafael
    http://www.nagavideo.com
  • Andrew Parker
    September 11, 2009 at 4:24 pm
    Thanks for the reply Rafael
    I am a little concerned that this is quite a major procedure half way through a project- and possibly risky- in that it could lead to further issues.
    Am I being over-cautious?
    A gradually worsening playback performance could be bad news as well.
    What is the AJA tool for checking RAID performance? I don’t have an AJA box.
    Thanks again
    Andrew
  • Rafael Amador
    September 12, 2009 at 1:54 am
    Hi Andrew,
    No problem to run Diskwarrior in the middle of any project.
    I run it every week whatever the job I’m doing.
    You can download the AJA software from their web site. I guess comes with the KONA drivers.
    rafael
