Activity Forums Apple Final Cut Pro Legacy timeline format Easy setup
  • timeline format Easy setup
    Posted by Ryan Vanderbek on May 13, 2009 at 7:34 pm
    Hi, I’m doing animatics for an animated show. When the show goes to online it will be in HD. Do I need to set Easy Setup to an HD format for the animatics? Do I need to use the same sequence settings the Online editor will eventually use?
    Ryan Vanderbek replied 17 years, 3 months ago 2 Members · 2 Replies
  • John Fishback
    May 13, 2009 at 8:18 pm
    Are the animatics the final product that will be used in the HD show, or are they just an approximation?
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Ryan Vanderbek
    May 13, 2009 at 9:59 pm
    Hi, thanks for the reply, No from the animatics the animation will be made which the Offline editor will use.
