Activity › Forums › Apple Final Cut Pro Legacy › Timeline / Blade problem
  • Timeline / Blade problem
    Posted by Lance Kaplan on October 26, 2008 at 4:30 pm
    I have a sequence I’m trying to color-correct. I don’t have the original files that made up the sequence, however; I only have the uncompressed, exported QT video. In order divide the sequence into clips, I am using the Blade.
    Here is my problem: When I add the Color Correct filter to a clip I’ve created, the filter is not only applied to the clip itself, but to the first frame following the clip. When I try to fix this by applying the filter to that frame, then the reverse problem occurs: The last frame of the clip is lacking the attributes of the filter.
    Is there a way to cut the clips within a video file in the timeline so that this doesn’t happen?
    Andy Mees replied 17 years, 11 months ago 3 Members · 2 Replies
