Activity Forums VEGAS Pro Timelapse in Sony Vegas 9
  • Timelapse in Sony Vegas 9
    Posted by Jake Secor on April 27, 2010 at 11:22 pm
    Is there a way to make a timelapse montage. I can only have a clip fast forward, but I want it to go even faster, I am trying to get a timelapse, but all it will do is just play in fast forward. any help?
    James Smith replied 14 years, 2 months ago 5 Members · 11 Replies
  • 11 Replies
  • John Rofrano
    April 28, 2010 at 12:46 am
    You can set the playback rate to 4x. Then add a Velocity envelope at 300% for another 3x. That’s 12x. Finally save this as a project (.veg) file and drop it into another project and do it all again. 4x playback rate will bring the 12x up to 48x and 300% on top of that is 144x. Repeat as necessary.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Jake Secor
    April 28, 2010 at 12:50 am
    Thank you, I’ll try it out.
  • James Smith
    June 20, 2012 at 6:52 pm
    I’m running Sony Vegas Movie Studio Platinum 9.
    I can set the playback rate to 4x as explained by John above. But when I go Insert>Video Envelopes>Event Velocity, ‘Event Velocity’ doesn’t appear as an option under Video Envelopes. The only 2 options under Video Envelopes are ‘Track Composite Level’ and ‘Track Fade to Colour’.
    So I can’t do this second step to speed up the video a further 3 times.
    Can anyone tell me where Video Envelopes is and how to proceed?
    Thanks in advance for any advice/info.
  • Mike Kujbida
    June 20, 2012 at 7:12 pm
    Sorry to be the bearer of bad news but Velocity envelopes are available in Vegas Pro only 🙁
  • James Smith
    June 20, 2012 at 7:30 pm
    Ah thanks. So, in Sony Vegas Movie Studio Platinum 9 (non pro version), is the only way to do time lapse to:
    1. Click on the R-hand furthermost edge of a clip, hold the ctrl button down until the wavy line appears and then drag the cursor as far as it will go to the left.
    2. Render.
    3. Repeat step 1 on the previously rendered footage?
    Will this produce acceptable results?
  • John Rofrano
    June 20, 2012 at 9:34 pm
    Stretch, Render, & Repeat is one way to do it. If you render to a lossless format like uncompressed or Huffyuv or Lagarith, you should be able to do this indefinitely with no loss of quality.
    You could also cut out frames. Just cut out one frame out of every 100 and keep it and delete the video in between and your video will run 100x faster (once you close the gaps). This can be automated in Vegas Pro but Movie Studio doesn’t support scripting so you would have to do this manually.
    ~jr
  • James Smith
    June 21, 2012 at 11:29 pm
    Thanks John and Mike.
    Here was my first attempt:
    https://www.youtube.com/watch?v=P4snLlCVQrU
  • John Rofrano
    June 23, 2012 at 4:21 pm
    [James Smith] “Here was my first attempt:”
    Nice! 🙂
    ~jr
  • James Houghtaling
    June 25, 2012 at 4:00 am
    Nice one James, glad you got it sorted out.
    My Hardware:
    Core i7 2.67GHz; Nvidia GTX580, 12 gig RAM Win7 64bit.
    My Software:
    Vegas Pro V11 with Boris Continuum Complete 8, VASST Ultimate S; Bluff Titler; AE5; PhotoPaint and other stuff.
  • Mike Kujbida
    June 25, 2012 at 2:12 pm
    Great job James!! You should be very proud of this.
