Activity Forums Adobe Premiere Pro Timelapse Export keeps Failing
  • Timelapse Export keeps Failing
    Posted by Luke Dreser on February 25, 2009 at 12:51 am
    Hi, I have a problme that has been haunting me for a while now, and I can’t seem to find a solid solution for it.
    Everytime I try to export heavily sped up (10k times) video, Adobe Media Encoder fails, and gives me nice little yellow Caution Triangle with no error message.
    I use Canon HF10, bring up the AVCHD’s into 60i Timeline. Speed it up, render the timeline, and export. I need it to be in Quicktime format and lossless or close to lossless. I’ve tried Sheer codec, YUV 10bit as well as NO compression at all. Switch it to Progressive Field order, and pixel Square Aspect Ratio. Resolution is 1920×1080 obviously.
    The export fails after about 5 minutes of the process. I’ve tried reinstalling Premiere, changing the sequence settings, even doing a smaller time compression (2500x)
    Am I doing something wrong ? or is it just Premiere not being able to handle this large amount of time compression ?
    thx for any feedback
    Here is my System –
    Intel Quad 9550
    ATI HD4870x2
    4GB MEM
    640GB SATA
    Running Premiere CS4 4.0.1
    Luke Dreser replied 17 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
