Activity Forums Apple Final Cut Pro Legacy timecode Problem 911!!!!!
  • timecode Problem 911!!!!!
    Posted by Julio C maldonado on May 19, 2008 at 8:32 pm
    i have a problem with the timecode burner. i have a movie that is in 720 24p and. i need to send this in 29.97 ndf to a musician so he can work with it. but when i exported the movie the timecode and everything is fine, but when i opened it in quicktime player the timecode window burner it’s 1:24:33 the real time but in the timecode of quicktimeplayer it’s 1:24:39…and that’s the problem that i have i need it to match it…any suggestions..or what i’m doing wrong…let me know thanks.
    JC
    Chris Borjis replied 18 years, 3 months ago 3 Members · 2 Replies
  • Tom Behrens
    May 19, 2008 at 9:11 pm
    pretty sure that making a new sequence with 29.97 time code and then copying and pasting your cut into the new sequence and then exporting will fix your problem
  • Chris Borjis
    May 19, 2008 at 9:15 pm
    [Julio C Maldonado] “i need to send this in 29.97 ndf to a musician so he can work with it”
    your musician needs to set his software to work with 23.98 ndf.
    You could have a re-synching nightmare if you try it the way you are going.
