Activity Forums VEGAS Pro Timecode Output Larger than Specified
  • Timecode Output Larger than Specified
    Posted by Sam Nicholls on September 21, 2009 at 3:48 pm
    Hi folks,
    This may be a very pointless question but I cannot seem to find an answer in any settings!
    I’ve applied a Sony Timecode Media FX to an event, as I’m sure you all know this FX allows you to specify a width and height which I have entered as 0.8 and 1.0 respectively – As the timecode just seems tidier with narrower text.
    However, upon rendering, the timecode appears as if I’d set the dimensions as 1.0 by 1.0 – This isn’t a massive issue, but whenever I come across a problem I cannot leave it alone!
    Sam.
    Sam Nicholls replied 17 years ago 1 Member · 0 Replies
  • 0 Replies
