Activity Forums Apple Final Cut Pro Legacy Timecode navigation using source timecode
  • Timecode navigation using source timecode
    Posted by Darryl David on September 21, 2009 at 11:01 am
    Hello, Here is what I would like to do. I know in avid land i can dump a bunch of testimonials into a timeline that have been shot on different days so the timecode is different. I can then load that sequence into the source monitor and from the timecode menu tell the sequence in the source to use the source timecode from tape to navigate. If I do this in fcp i am limited to just the sequence time. Is there a way to do this? Same goes for navigating in the viewer with a sequence open. Say I want to use timecode reference from the source and not the sequence timecode. There surely must be a way. This is most useful. I know I could just matchframe but that’s the easy way out.
    We don’t want to be limited to always navigating with sequence time. That is what the floating timecode window is for. This new timecode viewer is a big step for final cut but still very limiting.
    I also find that is doesn’t give me info when parked on a clip in the timeline. I have to matchframe it to get the label displays. Kinda wonky.
    Thank you,
    Darryl
    dedit
    freelance editor
    toronto
    Bob Flood replied 17 years ago 5 Members · 7 Replies
  • 7 Replies
  • Tom Wolsky
    September 21, 2009 at 1:26 pm
    That functionality is not in FCP. The application is not designed to work the way you work unfortunately.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • Joe Paolo
    September 21, 2009 at 2:07 pm
    You can turn on timecode overlays in the source window. Don’t think you can keystroke to thre source times but you can see them if that helps.
    joe
    editmojo.com
  • Bob Flood
    September 21, 2009 at 2:11 pm
    Darryl,
    As Tom had so succinctly put it, It aint gonna happen with FCP
    However
    If you tell us what your goal is, we can tell you the best way to achieve it using FCP.
    something like “I need to be able to cue my source clips from TC notes in a transcript.” versus “i want to do something an Avid does”
    so waddya wanna do? we be happy to help!
    “I like video because its so fast!”
    Bob Flood
    Greer & Associates, Inc.
  • Darryl David
    September 21, 2009 at 2:49 pm
    Thank you for your reply. Yes I would like to cue from tanscripts with timecode
    notes. If there is another way other than
    to matchframe that would be great. I guess the other way to do then is to put
    All related debriefs into a folder instead
    of putting them into a sequence. Then just open the appropriate clip and punch in the timecode from there. It’s a different workflow but again different program structure. Final cut is folder driven avid is bin and sequence structured.
    dedit
    freelance editor
    toronto
  • Andy Mees
    September 21, 2009 at 3:34 pm
    Daryl
    Assuming there is no duplication of source timecode then as a reasonably simple workaround you could arrange the source clips in selects sequences in such a way that the source timecodes exactly match up with selects sequence’s timecode … in that way you could navigate your selects reel in the manner you’re looking for.
    You can do this pretty easily by creating and using Multiclip Sequences as your selects sources (bulk select the sources clips and then choose Modify menu > Make Multiclip Sequence.. the resulting sequence is the selects sequence and should contain all the source clips laid out as described above. I’ve never tried this with wildly disparate timecodes and there may be a limit that I’m not aware of, but in theory it should work fine.
    Hope it helps
    Andy
  • Darryl David
    September 21, 2009 at 5:18 pm
    Good idea Andy. I will try it out. My best bet might be to just load the clip i need into the viewer and go from there.
    Thanks all.
    dedit
    freelance editor
    toronto
  • Bob Flood
    September 21, 2009 at 6:12 pm
    Darryl
    I do this all the time. The client or writer goes through transcripts in Word and builds a script from the transcript, using the time code number from the question, or just after.
    make a bin (what you call a folder) of all your interviews/testimonials.
    load into the source viewer, and cue up each one through the timecode. THEN play the clips from their and mark in and out on the actual statement you need.
    at this point you can cut it into a sequence, OR make a subclip which will show up back in the bin. If you are looking for multiple statements from a single take, you cna use markers as well (which you can later turn into subclips, if you desire.
    just another way to skin the proverbial cat (cuz you know PETA would’nt let us skin a real cat 🙂 )
    hope this helps
    Bob Flood
