Activity › Forums › Media 100 › Timecode issue
  • Timecode issue
    Posted by Chris Stevens on October 17, 2008 at 11:39 am
    I capture SDI HD into my Media 100 HDx (V12.0.3) using the HDx hardware to scale & downconvert to SD. For some reason the Timecode does not pass through & every clip digitised starts at 0.
    Any ideas?
    G5 dual 2.7, OS10.5.1, 4G RAM
    Media100 HD V12 & Producer, AE 7
    5.6 terra RAID
    Michael Slowe replied 17 years, 11 months ago 3 Members · 6 Replies
  • Floh Peters
    October 17, 2008 at 11:49 am
    Hm, what do you mean by “pass through”? You are doing the downconversion on acquire, I guess? Do you use RS422 deck control? What happens if you set your Media Standard to HD in the Video Input Prefs without changing anything else? Do you get Timecode then?
  • Chris Stevens
    October 17, 2008 at 12:41 pm
    Yes. Using downconversion on acquire. Can’t use RS422 control, as SDI signal coming from EX3. Will test HD acqiure when back in edit suite – next monday. Thanks Floh.
    5.6 terra RAID
  • Floh Peters
    October 17, 2008 at 12:42 pm
    So you are using FireWire as deck control? Without a deck control you don´t get TC.
  • Chris Stevens
    October 17, 2008 at 12:46 pm
    OK I now understand that without Deck Control Media 100 will not see TC.
    Can I use Firewire deck control while capturing SDI?
    5.6 terra RAID
  • Floh Peters
    October 17, 2008 at 12:50 pm
    [Chris Stevens] “Can I use Firewire deck control while capturing SDI?”
    Yes
  • Michael Slowe
    October 17, 2008 at 4:35 pm
    Chris, I have been using the EX1 for some months now and pending Media 100’s support for XDCAM I shot in SP mode, transferred via firewire to HDV tape and upscaled through Convergent Design to HD.
    Now that Media 100 version 13 supports EX media I propose upgrading to that and doing the whole thing properly, shooting HQ and staying HD for editing. Are you planning to do likewise?
    Michael Slowe
