Activity › Forums › Adobe Premiere Pro › Timecode in Dynamic Links between PPro and After Effects
  • Timecode in Dynamic Links between PPro and After Effects
    Posted by Oded Naaman on July 12, 2014 at 7:49 pm
    Hello
    I am working on an editing project where I have multiply cuts in Premiere (cs6), but it’a actually only 3 files of footage.
    When I moved to the post stage I thought it would be easier to just apply the color corrections and effects in AE on the 3 footage files, bring the compositions back to Premiere and just replace them on the timeline the same way you replace any clip in premiere (drag+alt).
    The problem is, that even though the timecode matches in AE, when I bring the composition into premiere the timecode resets to 00:00:00:00,
    and therefore cannot be matched with the cuts on the timelines.
    Thoughts on how to solve this?
    Oded
    Oded Naaman replied 12 years, 2 months ago 2 Members · 2 Replies
  • Daniel Hughes
    July 12, 2014 at 9:31 pm
    I would personally do it the other way around.
    If you have your cut ready in Premiere, you could replace that with an After Effects composition. In AE you can create a preset for each of the three shots, meaning it won’t take you much longer to apply a particular preset to different parts of the shot.
    Daniel Hughes
    Freelance photorgapher/videographer
    Filmmaker
    United Kingdom
  • Oded Naaman
    July 12, 2014 at 9:36 pm
    Thanks for the reply.
    I don’t think that would work well – I have key and multiply effects and layers for each footage file.
