Activity › Forums › Apple Final Cut Pro Legacy › timecode generation
timecode generation
Posted by Nikhil Venu on May 27, 2011 at 3:16 amhi
we are shoot a film in canon 7d.
how to insert timecode in 7d rushes?Bouke Vahl replied 15 years, 3 months ago 4 Members · 3 Replies -
Everest Mokaeff
May 27, 2011 at 6:52 amDownload plugin for fcp from canon then use L&T to ingest your material w/ TC.
Free-lance fcp editor in Moscow
http://www.mokaeff.com -
Shane Ross
May 27, 2011 at 7:22 amA couple of ways. Here’s a tutorial:
Adding visible timecode to QT exports
https://library.creativecow.net/ross_shane/visible-timecode/1OH, but first you need to convert the Canon footage to an editing format…ProRes. Tutorial for that here:
Tapeless Workflow for FCP 7 TutorialShane
Read my blog, Little Frog in High Def -
Bouke Vahl
May 27, 2011 at 8:27 amIf you want TC in your original (or copies) H264 material,
use this:
https://www.videotoolshed.com/product/42/qtchangeYou can also use it with transcoded material. (If you want to transcode outside FCP, aa lots of people do.)
For that, keep the filename the same or longer, and let the .thm files travel with the new clips, then run QTchange on the new clips.Procoder retains TC if you use that for transcoding.
And, as a bonus, it can add ‘burned in’ TC without transcoding.
(read, very fast)hth,
Bouke
smart tools for video pros
